Ana içeriğe geç
Xelio P900A-BK Front Facing Camera Replacement
Neye ihtiyacın var
  1. Xelio P900A-BK Front Facing Camera Replacement, Front Facing Camera: adım 1, 1 resimden 1.
    • Remove the two 5.4mm bottom screws.
    • Set aside.
  2. Xelio P900A-BK Front Facing Camera Replacement: adım 2, 3 resimden 1. Xelio P900A-BK Front Facing Camera Replacement: adım 2, 3 resimden 2. Xelio P900A-BK Front Facing Camera Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
    • Gently work your way around the entire tablet and do not force the case open prematurely.
    • You will hear the plastic latches pop free.
  3. Xelio P900A-BK Front Facing Camera Replacement: adım 3, 1 resimden 1.
    • Remove the connection between the camera and the motherboard.
    • Open the black ribbon holder then remove the ribbon from its connection.
  4. Xelio P900A-BK Front Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
  5. Xelio P900A-BK Front Facing Camera Replacement: adım 5, 3 resimden 1. Xelio P900A-BK Front Facing Camera Replacement: adım 5, 3 resimden 2. Xelio P900A-BK Front Facing Camera Replacement: adım 5, 3 resimden 3.
    • Use the smaller plastic opening tool to remove the camera from its socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marcus Nelson
307 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G6
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 110
