Ana içeriğe geç
Xelio P900A-BK Screen Replacement
Neye ihtiyacın var
  1. Xelio P900A-BK Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove the two bottom screws.
    • The two bottom screws have a 2.44mm wide tops and are 5.44mm.
  2. Xelio P900A-BK Screen Replacement: adım 2, 2 resimden 1. Xelio P900A-BK Screen Replacement: adım 2, 2 resimden 2.
    • Slide the spludger between the screen's rolled edge and the back of the tablet and pry apart carefully. Expect the tablet screen to make a cracking sound.
    • Slide the spudger in the slit all the way around the perimeter of the tablet to fully separate the screen.
  3. Xelio P900A-BK Screen Replacement: adım 3, 1 resimden 1.
    • Once the screen has fully separated from the back of the tablet, gently lift up the edges to remove the screen.
  4. Xelio P900A-BK Screen Replacement: adım 4, 2 resimden 1. Xelio P900A-BK Screen Replacement: adım 4, 2 resimden 2.
    • Next, disconnect the front facing camera ribbon (shown). The ribbon is held to the motherboard by a small bar.
    • Using the spudger to pry open the bar, pull the ribbon out to disconnect it.
  5. Xelio P900A-BK Screen Replacement: adım 5, 2 resimden 1. Xelio P900A-BK Screen Replacement: adım 5, 2 resimden 2.
    • Next, work on disconnecting the ribbon for the touch screen.
    • The touch screen ribbon is larger than the camera ribbon and is located on the left side of motherboard.
    • Using the spudger, gently pry the ribbon out from under the bar. Pull the ribbon and disconnect it from the motherboard.
  6. Xelio P900A-BK Screen Replacement: adım 6, 3 resimden 1. Xelio P900A-BK Screen Replacement: adım 6, 3 resimden 2. Xelio P900A-BK Screen Replacement: adım 6, 3 resimden 3.
    • Next, work to disconnect the LCD screen ribbon.
    • This ribbon is located on the right side of the motherboard.
    • The ribbon is connected to the motherboard by a small bar. Using the spudger, pry the bar apart and slide the ribbon out.
  7. Xelio P900A-BK Screen Replacement: adım 7, 3 resimden 1. Xelio P900A-BK Screen Replacement: adım 7, 3 resimden 2. Xelio P900A-BK Screen Replacement: adım 7, 3 resimden 3.
    • Remove the two motherboard screws.
    • To remove the first screw, expose the black strip. Then using a Philips head screwdriver, remove the first screw.
    • Locate the second screw by looking to the bottom right of the motherboard. Remove the second screw with the Philips head screwdriver.
  8. Xelio P900A-BK Screen Replacement: adım 8, 2 resimden 1. Xelio P900A-BK Screen Replacement: adım 8, 2 resimden 2.
    • Locate the last connection to the LCD in the top right section of the tablet.
    • The last connection is a ribbon connected to green wire, which is held down by tape.
    • Disconnect the ribbon by removing the tape connecting it to the plastic frame of the tablet.
  9. Xelio P900A-BK Screen Replacement: adım 9, 1 resimden 1.
    • With the spudger, pry the LCD screen from the plastic screen holder.
    • Use gentle, but firm force to pry the LCD away from the holder.
  10. Xelio P900A-BK Screen Replacement: adım 10, 1 resimden 1.
    • Work the spudger all the way around until the LCD is free from the screen holder.
  11. Xelio P900A-BK Screen Replacement: adım 11, 1 resimden 1.
    • Finally, lift the LCD off, removing it from the screen holder and the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marcus Nelson
307 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G6
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 392
