Ana içeriğe geç
Xerox B201 Toner Roller Replacement
Neye ihtiyacın var
  1. Xerox B201 Toner Roller Replacement, Xerox B201 Toner Roller: adım 1, 3 resimden 1. Xerox B201 Toner Roller Replacement, Xerox B201 Toner Roller: adım 1, 3 resimden 2. Xerox B201 Toner Roller Replacement, Xerox B201 Toner Roller: adım 1, 3 resimden 3.
    • Start by pressing the rectangular button on the top-front side of your printer.
    • A door will open, exposing two parts on top of each other, the toner cartridge on top and the toner drum on the bottom.
    • Use the handle of toner cartridge to slide it out towards you.
    • You will be working on this particular part.
  2. Xerox B201 Toner Roller Replacement: adım 2, 3 resimden 1. Xerox B201 Toner Roller Replacement: adım 2, 3 resimden 2. Xerox B201 Toner Roller Replacement: adım 2, 3 resimden 3.
    • Rotate the toner cartridge so that the handle is facing away from you and the ink roller is facing you.
    • Use the Phillips #0 screwdriver to remove the two 6.5 mm screws on each side of the toner cartridge.
  3. Xerox B201 Toner Roller Replacement: adım 3, 3 resimden 1. Xerox B201 Toner Roller Replacement: adım 3, 3 resimden 2. Xerox B201 Toner Roller Replacement: adım 3, 3 resimden 3.
    • On the right side, hold the toner cartridge firmly with one hand, and use your fingers to remove the plastic casing which covers the gearbox.
    • Use a small plier to remove the three white gears from the toner cartridge.
    • Don't remove the two black gears.
  4. Xerox B201 Toner Roller Replacement: adım 4, 2 resimden 1. Xerox B201 Toner Roller Replacement: adım 4, 2 resimden 2.
    • Remove the plastic casing on the other side of the toner cartridge.
    • Remove the rectangular plastic case, (that protects the toner roller), in the center of the toner cartridge.
  5. Xerox B201 Toner Roller Replacement: adım 5, 3 resimden 1. Xerox B201 Toner Roller Replacement: adım 5, 3 resimden 2. Xerox B201 Toner Roller Replacement: adım 5, 3 resimden 3.
    • Rotate the toner cartridge so that the metal line is facing you.
    • The black cylinder is the toner roller.
    • Remove the two white circular spacers on both sides of the toner cartridge.
    • Use pliers to remove them if they are difficult to remove by hand.
    • Hold the end of the right side of the toner roller by the metal rod.
    • Hold the toner cartridge firmly with your other hand and remove the toner roller.
  6. Xerox B201 Toner Roller Replacement: adım 6, 2 resimden 1. Xerox B201 Toner Roller Replacement: adım 6, 2 resimden 2.
    • Use a clean and dry, lint-free cloth to remove any spilled ink on the outsides of the hopper.
    • Do NOT touch the inside of the toner cartridge with your hand or cloth.
    • Hold the metal ends of the new toner roller and carefully put it back in place.
    • Do NOT touch the toner roller with your hands or a cloth. Use the metal ends on each side of the toner roller.
  7. Xerox B201 Toner Roller Replacement: adım 7, 2 resimden 1. Xerox B201 Toner Roller Replacement: adım 7, 2 resimden 2.
    • Place the two white circular spacers back on both sides of the toner roller.
    • Place the three white gears back on the right side of the toner roller.
    • Make sure the three white gears are in place, and that they all rotate synchronously.
  8. Xerox B201 Toner Roller Replacement: adım 8, 3 resimden 1. Xerox B201 Toner Roller Replacement: adım 8, 3 resimden 2. Xerox B201 Toner Roller Replacement: adım 8, 3 resimden 3.
    • Place the plastic case back on the toner cartridge.
  9. Xerox B201 Toner Roller Replacement: adım 9, 2 resimden 1. Xerox B201 Toner Roller Replacement: adım 9, 2 resimden 2.
    • Use a Phillips #0 screwdriver to put the four 6.5 mm Phillips #0 screws back in place.
    • Place the toner cartridge back in your printer. You are done!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rami Yamout
224 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Nice work! I like that you used a clear and a free from distraction background on your photos. Your guide is concise and easy to follow (thanks to your choice of simple words!) Keep up the good work.
LOU ERIKA U MUEGA - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 1,188
