Giriş
For problems pertaining to poor camera quality, please read this guide. This guide is for replacing the back-facing Camera on the Xgody D300. Please follow the steps carefully. By the end, your phone should be working as it normally should.
Neye ihtiyacın var
Using the Phillips #00 screwdriver, remove the screws that hold the protective housing to the smartphone; there should be 14 screws with a length of 3mm and one screw with a length of 6mm.
Three of the screws will not come loose from the protective housing and can be identified by a metal plate that is underneath them. In total there is 18.
