Ana içeriğe geç
Xiaomi Air 12 Battery Replacement
Neye ihtiyacın var
    1. Xiaomi Air 12 Battery Replacement, Rear Casing: adım 1, 1 resimden 1.
      • Orient the computer so the Xiaomi logo is at the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Air 12 Battery Replacement: adım 2, 3 resimden 1. Xiaomi Air 12 Battery Replacement: adım 2, 3 resimden 2. Xiaomi Air 12 Battery Replacement: adım 2, 3 resimden 3.
      • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Air 12 Battery Replacement: adım 3, 2 resimden 1. Xiaomi Air 12 Battery Replacement: adım 3, 2 resimden 2.
      • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    4. Xiaomi Air 12 Battery Replacement: adım 4, 3 resimden 1. Xiaomi Air 12 Battery Replacement: adım 4, 3 resimden 2. Xiaomi Air 12 Battery Replacement: adım 4, 3 resimden 3.
      • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
      • You will hear popping noises as you remove the cover.
      FixBot'a Sor
      Yorum Ekle
    5. Xiaomi Air 12 Battery Replacement: adım 5, 2 resimden 1. Xiaomi Air 12 Battery Replacement: adım 5, 2 resimden 2.
      • Remove the back of the laptop by gently lifting the casing upwards.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Air 12 Battery Replacement, SSD: adım 6, 2 resimden 1. Xiaomi Air 12 Battery Replacement, SSD: adım 6, 2 resimden 2.
      • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Air 12 Battery Replacement: adım 7, 2 resimden 1. Xiaomi Air 12 Battery Replacement: adım 7, 2 resimden 2.
      • Remove the 1.5mm screw using the JIS #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Air 12 Battery Replacement: adım 8, 2 resimden 1. Xiaomi Air 12 Battery Replacement: adım 8, 2 resimden 2.
      • Lift the SSD up from the device and gently pull the SSD from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Air 12 Battery Replacement, Battery: adım 9, 1 resimden 1.
      • Detach the red wire from the tabs on the perimeter of the metal bracket.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Air 12 Battery Replacement: adım 10, 3 resimden 1. Xiaomi Air 12 Battery Replacement: adım 10, 3 resimden 2. Xiaomi Air 12 Battery Replacement: adım 10, 3 resimden 3.
      • Use a PH1 screwdriver to remove the five 2mm black screws.
      • Remove two silver 1mm JIS #00 screws.
      • There will be clear plastic spacers that come off with the silver screws.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Air 12 Battery Replacement: adım 11, 3 resimden 1. Xiaomi Air 12 Battery Replacement: adım 11, 3 resimden 2. Xiaomi Air 12 Battery Replacement: adım 11, 3 resimden 3.
      • Lift the battery up and pull out from the device.
      • The metal bracket will come out with the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Hannah Kwan
928 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G4
4 Üyeler
46 adet Kılavuz yazıldı
6Kılavuz Yorumları
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
Migwell2 - Yanıt Paylaş
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
Roma Monica Desunia - Yanıt Paylaş
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot - Yanıt Paylaş
after I change the battery it always says plugged in not charge, anyone has the same issue?
Anthony Jethro Lieander - Yanıt Paylaş
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hamed Mirrezaee - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 148
Her zaman: 13,347
