Ana içeriğe geç
Xiaomi Mi 3 Phone Vibrator Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 3 Phone Vibrator Replacement, Battery: adım 1, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement, Battery: adım 1, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement, Battery: adım 1, 3 resimden 3.
    • Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
  2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 2, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 2, 2 resimden 2.
    • Remove the two Phillips head screws located at the top of the phone on either side where the SIM card was ejected.
    • One screw is located under an orange sticker which would serve as your warranty for the camera were this practice not illegal as per the Magnuson–Moss Warranty Act of 1975.
  3. Xiaomi Mi 3 Phone Vibrator Replacement: adım 3, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 3, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 3, 3 resimden 3.
    • Insert a pry tool into the upper edge of the phone, where there is a small gap between screen and frame of the phone to begin separating the screen from the rest of the phone.
    • Be careful when using the pry tool as it can damage the phone's screen or other components.
  4. Xiaomi Mi 3 Phone Vibrator Replacement: adım 4, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 4, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 4, 3 resimden 3.
    • Once the pry tool has been inserted into the phone, slide it around the perimeter of the phone while gently lifting until the screen panel and back panel of the phone separate.
  5. Xiaomi Mi 3 Phone Vibrator Replacement: adım 5, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 5, 2 resimden 2.
    • The back of the phone should now be separated from the screen.
  6. Xiaomi Mi 3 Phone Vibrator Replacement: adım 6, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 6, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the front panel screen side down with the camera at the top.
    • Remove these six Phillips head screws located at the upper half of the phone.
    • This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
  7. Xiaomi Mi 3 Phone Vibrator Replacement: adım 7, 1 resimden 1.
    • Next, remove these three screws located at the bottom of the back panel.
  8. Xiaomi Mi 3 Phone Vibrator Replacement: adım 8, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 8, 2 resimden 2.
    • Using tweezers, remove the rubber dust cover on the back panel of the phone.
  9. Xiaomi Mi 3 Phone Vibrator Replacement: adım 9, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 9, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 9, 3 resimden 3.
    • Remove the plastic cover on the bottom of the back panel by inserting the pry tool at the edge and gently lifting.
  10. Xiaomi Mi 3 Phone Vibrator Replacement: adım 10, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 10, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 10, 3 resimden 3.
    • Remove the upper plastic cover from the back panel by inserting the pry tool into the upper edge and gently lifting.
    • Some models have the NFC antenna at the back of the battery glued to the top cover. It is not possible to remove the top cover without removing the battery as well. For these models, check the touchscreen guide for instructions.
  11. Xiaomi Mi 3 Phone Vibrator Replacement: adım 11, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 11, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 11, 3 resimden 3.
    • Using a spudger, remove the small ribbon cable that is connected to the battery.
  12. Xiaomi Mi 3 Phone Vibrator Replacement: adım 12, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 12, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 12, 3 resimden 3.
    • Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
    • Some force may be required to remove the battery since it is adhered to the phone with two pieces of double sided tape.
  13. Xiaomi Mi 3 Phone Vibrator Replacement: adım 13, 1 resimden 1.
    • The battery is now removed from the panel.
  14. Xiaomi Mi 3 Phone Vibrator Replacement, Motherboard: adım 14, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement, Motherboard: adım 14, 2 resimden 2.
    • Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
  15. Xiaomi Mi 3 Phone Vibrator Replacement: adım 15, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 15, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 15, 3 resimden 3.
    • Use a pry tool to separate the LCD display cable from the motherboard. The cable connects to the motherboard as a rectangular metallic piece at the bottom right of the motherboard.
  16. Xiaomi Mi 3 Phone Vibrator Replacement: adım 16, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 16, 2 resimden 2.
    • Disconnect the gold ribbon cable for the LCD display by gently inserting the pry tool under the wide end and lifting up.
  17. Xiaomi Mi 3 Phone Vibrator Replacement: adım 17, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 17, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 17, 3 resimden 3.
    • Separate a cable ribbon from the top right of the motherboard by gently inserting the pry tool under the rectangular metallic piece and lifting.
  18. Xiaomi Mi 3 Phone Vibrator Replacement: adım 18, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 18, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 18, 3 resimden 3.
    • Separate a cable ribbon from the top right of the motherboard - near the cable from the previous step - by gently inserting the pry tool under the rectangular metallic piece and lifting.
  19. Xiaomi Mi 3 Phone Vibrator Replacement: adım 19, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 19, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 19, 3 resimden 3.
    • Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
  20. Xiaomi Mi 3 Phone Vibrator Replacement: adım 20, 2 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 20, 2 resimden 2.
    • Remove these two screws.
  21. Xiaomi Mi 3 Phone Vibrator Replacement: adım 21, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement: adım 21, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement: adım 21, 3 resimden 3.
    • Remove the motherboard from the panel carefully. Use the pry tool as a lever from the top of the panel and lift if from that side.
  22. Xiaomi Mi 3 Phone Vibrator Replacement: adım 22, 1 resimden 1.
    • The motherboard has now been successfully removed.
  23. Xiaomi Mi 3 Phone Vibrator Replacement, Phone Vibrator: adım 23, 3 resimden 1. Xiaomi Mi 3 Phone Vibrator Replacement, Phone Vibrator: adım 23, 3 resimden 2. Xiaomi Mi 3 Phone Vibrator Replacement, Phone Vibrator: adım 23, 3 resimden 3.
    Satın Al
    • With the motherboard removed you can use tweezers to remove the vibrator rather easily.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Howard
705 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Remmell Fall 2015 USF Tampa, Team 1-5, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 2,297
