Neye ihtiyacın var
Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
Bu adımda kullanılan alet:Tweezers$4.99
Place the front panel screen side down with the camera at the top.
Remove these six Phillips head screws located at the upper half of the phone.
This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
Next, remove these three screws located at the bottom of the back panel.
Using tweezers, remove the rubber dust cover on the back panel of the phone.
Why do you need to remove that ?
This step is 100% unnecessary.
Using a spudger, remove the small ribbon cable that is connected to the battery.
Thank you, i changed the battery mi3 easily. I dont need steep 9,10,11. I removed nfc stickers that stick to battery and attached to top cover carefully, make it top cover and antenna nfc still integrated. Mi3 Battery is removed Due problem "Bootloop mi logo without android, and you can enter fastboot only, no matter it sucessfully flashed via fastboot room it will stay bootloop". So, yes, if the battery not good, it will goes to bootloop automatically.
I have the same problem. I think my battery also dead! Good information!
Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
Use of an old credit card to help lift the battery Is much easier.
Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
This step Is absolutly NOT needed for motherboard removal.
You will people brake flex doing so. Limit your guide to necessary step only!
After removing the motherboard, use a pry tool to gently remove the camera's ribbon cable from the motherboard.
Bir başkası bu kılavuzu tamamladı.
