Ana içeriğe geç
Xiaomi Mi 4 Motherboard Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: adım 1, 3 resimden 1. Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: adım 1, 3 resimden 2. Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: adım 1, 3 resimden 3.
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Motherboard Replacement: adım 2, 3 resimden 1. Xiaomi Mi 4 Motherboard Replacement: adım 2, 3 resimden 2. Xiaomi Mi 4 Motherboard Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Metal Spudger
    $2.99
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Motherboard Replacement: adım 3, 3 resimden 1. Xiaomi Mi 4 Motherboard Replacement: adım 3, 3 resimden 2. Xiaomi Mi 4 Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Motherboard Replacement, Battery: adım 4, 3 resimden 1. Xiaomi Mi 4 Motherboard Replacement, Battery: adım 4, 3 resimden 2. Xiaomi Mi 4 Motherboard Replacement, Battery: adım 4, 3 resimden 3.
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Motherboard Replacement: adım 5, 2 resimden 1. Xiaomi Mi 4 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
  6. Xiaomi Mi 4 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
  7. Xiaomi Mi 4 Motherboard Replacement: adım 7, 2 resimden 1. Xiaomi Mi 4 Motherboard Replacement: adım 7, 2 resimden 2.
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
William Pendeergraft
2.441 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Blackwell Fall 2015 USF Tampa, Team 15-6, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G6
2 Üyeler
11 adet Kılavuz yazıldı
9Kılavuz Yorumları
Ruined my motherboard to Xiaomi mi4c, do you know where can I buy?
Milos Milos - Yanıt
I have broken one of the cable connections on the motherboard ( top one in Step 6). Do you know where I can buy a new motherboard?
Ben Dungey - Yanıt
you can buy the motherboard on taobao.com
Dong Zhengyue -
sim card reader is damaged. Do I need to have whole motherboard replaced
Shravan - Yanıt
sir i need MI4I motherboard unable to find elsewhere
Mobile # 09060907775
Thalanki Balaji - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 87
Her zaman: 37,221
