Ana içeriğe geç
Xiaomi Mi 4 Rear Case/Midframe Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 3.
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Metal Spudger
    $2.99
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 3.
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Robert Cobaich
2.106 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 69
Her zaman: 4,607
