Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Xiaomi Mi 4 Rear Case/Midframe Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: adım 1, 3 resimden 3.
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Metal Spudger
    $2.99
    Satın Al
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 1. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 2. Xiaomi Mi 4 Rear Case/Midframe Replacement: adım 3, 3 resimden 3.
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Robert Cobaich
2.073 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G1
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 4,266
