Ana içeriğe geç
Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement
Neye ihtiyacın var
  1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): adım 1, 2 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): adım 1, 2 resimden 2.
    • Turn off and remove the SIM card.
  2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 2, 3 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 2, 3 resimden 2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 2, 3 resimden 3.
    • Apply heat to loosen the back cover adhesive. Then remove it carefully.
  3. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 3, 2 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 3, 2 resimden 2.
    • Remove all nine screws that hold the shield protecting the motherboard.
  4. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 4, 3 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 4, 3 resimden 2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 4, 3 resimden 3.
    • Remove the shield and disconnect the battery connector, LCD and touch connector, and touch ID connector.
  5. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 5, 3 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 5, 3 resimden 2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 5, 3 resimden 3.
    • Remove the battery carefully as shown and apply heat to loosen the adhesive holding the screen.
  6. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 6, 3 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 6, 3 resimden 2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 6, 3 resimden 3.
    • Carefully start to separate the screen as shown. Start from the top corner.
  7. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 7, 2 resimden 1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: adım 7, 2 resimden 2.
    • You have done it.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kefelegn Derbew
553 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 33
Son 30 gün: 88
Her zaman: 7,402
