Ana içeriğe geç
Xiaomi Mi Note Battery Replacement
Neye ihtiyacın var
  1. Xiaomi Mi Note Battery Replacement, Battery: adım 1, 2 resimden 1. Xiaomi Mi Note Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    FixBot'a Sor
    Yorum Ekle
  2. Xiaomi Mi Note Battery Replacement: adım 2, 3 resimden 1. Xiaomi Mi Note Battery Replacement: adım 2, 3 resimden 2. Xiaomi Mi Note Battery Replacement: adım 2, 3 resimden 3.
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
    FixBot'a Sor
    Yorum Ekle
  3. Xiaomi Mi Note Battery Replacement: adım 3, 1 resimden 1.
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Xiaomi Mi Note Battery Replacement: adım 4, 2 resimden 1. Xiaomi Mi Note Battery Replacement: adım 4, 2 resimden 2.
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Mark Sears
1.265 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G6
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 38,853
