Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace your Xiaomi Mi Note's front facing camera.
  1. Locate the hole for the Dual SIM SD card on the left side of the phone.
    • Locate the hole for the Dual SIM SD card on the left side of the phone.
  2. Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out. Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
    • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
  3. Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free. Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  4. Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed. Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels. Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  5. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  6. Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  7. Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame. Glue will be holding down the backside of the battery.
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
  8. Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
    • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
  9. Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion. You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
    • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • When detaching the ribbon on the left use minimal force to prevent damage.
  10. Use a tweezer to lift and remove the motherboard from the frame. Be sure that the Dual SIM card and tray has been removed.
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
  11. The front camera is attached to the motherboard by a ribbon, use tweezers  to detach it from the motherboard.
    • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Abdulaziz Aldekheel
329 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,102
