Ana içeriğe geç
Xiaomi Mi Pad Headphone Jack Replacement
Neye ihtiyacın var
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: adım 1, 1 resimden 1.
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: adım 2, 2 resimden 1. Xiaomi Mi Pad Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: adım 3, 2 resimden 1. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: adım 3, 2 resimden 2.
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: adım 4, 1 resimden 1.
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rene Mendoza
311 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G5
3 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
And where to buy? :-(
marcusvoag - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 2,443
