Ana içeriğe geç
Xiaomi Mi Pad Motherboard Replacement
Neye ihtiyacın var
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: adım 1, 1 resimden 1.
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: adım 2, 2 resimden 1. Xiaomi Mi Pad Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Xiaomi Mi Pad Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: adım 6, 2 resimden 1. Xiaomi Mi Pad Motherboard Replacement: adım 6, 2 resimden 2.
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: adım 7, 1 resimden 1.
    • Carefully remove the motherboard from the device.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Kiefer Sivitz
560 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G5
3 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - Yanıt
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Yanıt
I want mi pad mother board
Where I buy
Sunil - Yanıt
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 6,584
