Ana içeriğe geç
Xiaomi Mi Pad Rear Camera Replacement
Neye ihtiyacın var
  1. Xiaomi Mi Pad Rear Camera Replacement, Rear Case Assembly: adım 1, 1 resimden 1.
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Camera Replacement: adım 2, 2 resimden 1. Xiaomi Mi Pad Rear Camera Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 1. Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 2.
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Rear Camera Replacement: adım 4, 1 resimden 1.
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Rear Camera Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to disconnect the rear-facing camera from the motherboard.
  6. Xiaomi Mi Pad Rear Camera Replacement: adım 6, 1 resimden 1.
    • Carefully remove the rear camera from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kiefer Sivitz
560 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G5
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 710
