Giriş
In this guide I will show you how to completely open the Roborock S5 (ROBOROCK S50200) to get to the components that are the most difficult to reach.
Neye ihtiyacın var
Insert the spudger from the side
Release the clips by turning the spudger
Lift the cover upwards
Loosen the 6 screws for the hinges
Lift and remove the hinges
Remove the flap upwards
Remove the main brush holder by pressing both locks inward and lifting it up.
Remove the main brush.
Remove the screw holding the side brush.
Remove the side brush along with the screw by lifting it upward.
Lift the front wheel with the screwdriver.
Completely pull the front wheel upward to remove it.
Remove the seven screws holding the bottom panel.
Lift the bottom cover up.
Remove the four screws from the main brush assembly
Lift out the main brush assembly upwards
Remove the 8 screws from the underside of the bumper
Remove the strip
Pull the bumper forwards, taking care not to bend the two metal plates
Remove the three screws from the motor
Pull the motor out upwards (plug connection with the circuit board)
remove the three screws from the drive unit
Remove wheel upwards (connected to a circuit board via plug connection)
Remove the three screws from the drive unit
Remove the wheel upwards (connected to the circuit board via a plug connection)
Work through the steps in reverse order to reassemble your device
Bu çevirmenlere özel teşekkürler:
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
