Ana içeriğe geç
Xiaomi Redmi 2 Ambient Light Sensor Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: adım 1, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 2, 1 resimden 1.
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 3, 1 resimden 1.
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 4, 1 resimden 1.
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 5, 1 resimden 1.
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 6, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 7, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 7, 2 resimden 2.
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 8, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 8, 2 resimden 2.
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 9, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 9, 2 resimden 2.
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 10, 2 resimden 1. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 10, 2 resimden 2.
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Ambient Light Sensor: adım 12, 1 resimden 1.
    • Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
  13. Xiaomi Redmi 2 Ambient Light Sensor Replacement: adım 13, 1 resimden 1.
    • Using your fingers, gently pull out the ambient light sensor.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Alicia Brenner
3.569 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G3
2 Üyeler
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 5,380
