Giriş
Use this guide to remove the motherboard in your Xiaomi Redmi 2 for repair or replacement.
Neye ihtiyacın var
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
47 farklı kişi bu kılavuzu tamamladı.
17Kılavuz Yorumları
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
how and where to buy motherboard for redmi2
i want new mothe board redmi
i want redmi 2 prime mother board
How to buy redmi prime 2 mother bord
hey my Redmi 2 is not working, what can I do? it started to make turn off it self time by time and after it turn off completly, if I make to turn it it on not working, it makes vibration only without turn on, what can I do?? please help me because am just seeking a help
Sir, my phone (Redmi 2 prime) doesn't starts. One day it got off on 0% charge. I put it on charge but from the next day it was not opening. What to do?
My phones mother bord is damaged I needed it
My phone is mother board damage I need it
Hello, i want ask for u, my handpone redmi 2 lte can’t on..why? What is problem?
السلام عليكم
لدي جوال شاومي s2
منفذالشاحن خربان
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - Yanıt
