Giriş
Use this guide to remove the screen assembly of your Xiaomi Redmi 2 for repair or replacement of any parts attached.
Neye ihtiyacın var
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
31 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
