Giriş
What You’ll Need:
- A set of screwdrivers
- Plastic prying tools
- Tweezers
- Replacement parts (like a new screen or battery)
- A heat source (like a hairdryer)
- A suction cup
- Some adhesive, if needed
Pro Tip: ===
If at any point you’re feeling unsure or if something seems off, it’s totally okay to take your phone to a professional. Sometimes it’s better to let the experts handle it.
Also for More details you can Oxrepair it from India
Neye ihtiyacın var
First, make sure your phone is completely turned off to avoid any electrical issues.
Pop out the SIM card tray using a paperclip or the tool that came with your phone. This step is simple but important.
Gently heat the edges of the screen with a hairdryer. This softens the glue, making it easier to open.
Attach a suction cup to the screen to lift it slightly. Then, use a plastic prying tool to carefully work your way around the edges. Be gentle to avoid breaking anything inside.
Once you’ve got the screen lifted, find the battery connector and gently unplug it. This step ensures you don’t accidentally short-circuit anything.
For a Cracked Screen: Disconnect the old screen and remove it. Connect the new screen’s cables and fit it into place.
For a Battery Replacement: Remove the old battery (which might be a bit sticky) and put the new one in. Connect it properly.
Carefully put the phone back together. Make sure everything clicks into place and reconnect any cables you unplugged.
Turn your phone back on and check to see if everything’s working as it should. Test the screen and any other functions to make sure they’re functioning correctly.
Pop the SIM card tray back into place once you’re sure the phone is working.
If needed, add some adhesive around the edges of the screen or back cover to make sure everything stays in place.
Pro Tip:
If at any point you’re feeling unsure or if something seems off, it’s totally okay to take your phone to a professional. Sometimes it’s better to let the experts handle it. You can also Oxrepair it if you're from India.
Bir başkası bu kılavuzu tamamladı.
