Giriş
This is a guide for the disassembly of the Xiaomi Redmi Note 3.
While not necessary, to complete this disassembly, folks are encouraged to have basic knowledge on the workings of phone electronics.
Neye ihtiyacın var
Locate the sim card tray at the right side of the phone
Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
Pull the black tab at the top left of the battery to disconnect the battery from the system
Bu adımda kullanılan alet:Tweezers$4.99
Wedge the tweezers under the battery to lift it up
Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
Remove the loud speaker cover using the tweezers to expose the daughterboard
Remove the two gold tabs on the two top corners of the daughterboard
Pry the daughterboard open with the tweezers or pull it out using your fingers
Unscrew the four screws at the top of the motherboard and pop up the top cover
Pull the tab that’s holding the front camera to remove the camera protector
Remove the five connectors of the motherboard using tweezers or your fingers
Remove the remaining four screws as your work down to the bottom to loosen the motherboard
