Ana içeriğe geç
Xiaomi Redmi Note 7 Rear Glass Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi Note 7 Rear Glass Replacement, Loosen the rear glass adhesive: adım 1, 1 resimden 1.
    • Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Xiaomi Redmi Note 7 Rear Glass Replacement, Insert an opening pick: adım 2, 3 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Insert an opening pick: adım 2, 3 resimden 2. Xiaomi Redmi Note 7 Rear Glass Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the rear glass.
    • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
  3. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the bottom edge adhesive: adım 3, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the bottom edge adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the lefthand-side adhesive: adım 4, 3 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the lefthand-side adhesive: adım 4, 3 resimden 2. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the lefthand-side adhesive: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner.
    • Slide the opening pick along the left edge of the phone to slice the rear glass adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the top edge adhesive: adım 5, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the top edge adhesive: adım 5, 2 resimden 2.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to slice the rear glass adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the righthand-side adhesive: adım 6, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Slice the righthand-side adhesive: adım 6, 2 resimden 2.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to slice the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The fingerprint sensor is still connected to the motherboard.
  7. Xiaomi Redmi Note 7 Rear Glass Replacement, Open up the phone assembly: adım 7, 3 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Open up the phone assembly: adım 7, 3 resimden 2. Xiaomi Redmi Note 7 Rear Glass Replacement, Open up the phone assembly: adım 7, 3 resimden 3.
    • Carefully fold the rear glass to the left side of the phone assembly like you'd open the front cover of a book.
    • Avoid tensioning the fingerprint flex cable during this process.
  8. Xiaomi Redmi Note 7 Rear Glass Replacement, Unfasten the screws: adım 8, 1 resimden 1.
    • Use a Phillips screw driver to remove the three 3.3 mm-long screws securing the connector cover to the midframe.
  9. Xiaomi Redmi Note 7 Rear Glass Replacement, Remove the connector cover: adım 9, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Remove the connector cover: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the connector cover.
  10. Xiaomi Redmi Note 7 Rear Glass Replacement, Disconnect the battery: adım 10, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Disconnect the battery: adım 10, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  11. Xiaomi Redmi Note 7 Rear Glass Replacement, Peel the protective foil off: adım 11, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Peel the protective foil off: adım 11, 2 resimden 2.
    • For easier handling during repairs we highly recommend to separate the back cover including the fingerprint sensor from the phone assembly.
    • Use a pair of tweezers to carefully peel the yellow protective foil off the ZIF connector.
  12. Xiaomi Redmi Note 7 Rear Glass Replacement, Open the ZIF connector: adım 12, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Open the ZIF connector: adım 12, 2 resimden 2.
    • Use the pointed end of a spudger to open the ZIF connector by bringing its black flap in an upright position.
  13. Xiaomi Redmi Note 7 Rear Glass Replacement, Disconnect the fingerprint flex cable: adım 13, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Disconnect the fingerprint flex cable: adım 13, 2 resimden 2.
    • Disconnect the fingerprint flex cable by pulling it straight out off the ZIF connector using a pair of tweezers.
  14. Xiaomi Redmi Note 7 Rear Glass Replacement, Soften the fingerprint adhesive: adım 14, 1 resimden 1.
    • Heat an iOpener and apply it to the rear glass where the finger print sensor is located to soften the adhesive. Apply the iOpener for at least two minutes.
  15. Xiaomi Redmi Note 7 Rear Glass Replacement, Cut the adhesive: adım 15, 3 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Cut the adhesive: adım 15, 3 resimden 2. Xiaomi Redmi Note 7 Rear Glass Replacement, Cut the adhesive: adım 15, 3 resimden 3.
    • Carefully slide an opening pick underneath the orange flex cable with the ZIF connector to separate it from the rear glass.
  16. Xiaomi Redmi Note 7 Rear Glass Replacement, Pry up the fingerprint sensor: adım 16, 2 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Pry up the fingerprint sensor: adım 16, 2 resimden 2.
    • Slide the tip of an opening pick underneath the edge of the fingerprint sensor.
    • Use the opening pick to pry up the fingerprint sensor.
  17. Xiaomi Redmi Note 7 Rear Glass Replacement, Remove the fingerprint sensor: adım 17, 3 resimden 1. Xiaomi Redmi Note 7 Rear Glass Replacement, Remove the fingerprint sensor: adım 17, 3 resimden 2. Xiaomi Redmi Note 7 Rear Glass Replacement, Remove the fingerprint sensor: adım 17, 3 resimden 3.
    • Remove the fingerprint sensor.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
231.367 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
1Rehber Yorum
Where buy protective foil for fingerprint sensor? Or can i use it second time?Thanks
Andriy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 2,148
