Ana içeriğe geç
Xiaomi Redmi Note 8 Pro Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Xiaomi Redmi Note 8 Pro Screen Replacement, Power Off Device: adım 1, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement, Power Off Device: adım 1, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement, Power Off Device: adım 1, 3 resimden 3.
    • Power off the phone by pressing the "Power" button located on the right side of the device.
    • When the power options screen appears, press the "Power" option.
    • Press the "Confirm Shutdown" option.
  2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 2, 2 resimden 2.
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  3. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 3, 2 resimden 2.
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Follow the iOpener Heating guide for instructions on using the iOpener.
  4. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 4, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  5. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 5, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 5, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 5, 3 resimden 3.
    • Once a plastic card is inserted in the seam, you can remove the suction cup.
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  6. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 6, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 6, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 6, 3 resimden 3.
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  7. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 7, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 10 screws from the plastic motherboard cover.
    • Use a Phillips screwdriver to remove the seven screws from the plastic button module.
  8. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 8, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 8, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 8, 3 resimden 3.
    • Use a spudger to pry up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
  9. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 9, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 9, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 9, 3 resimden 3.
    • Use the flat end of a spudger to disconnect all flex cables leading to the motherboard.
    • Use a pair of tweezers to gently disconnect the thin ribbon cable connecting to the motherboard's lower right-hand corner.
  10. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 10, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 10, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 10, 3 resimden 3.
    • Use the flat end of a spudger to gently pry up the motherboard.
    • Remove the motherboard.
  11. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 11, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 11, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 11, 3 resimden 3.
    • Remove the plastic button module using a pair of tweezers.
  12. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 12, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 12, 2 resimden 2.
    • Remove the superlinear speaker using a pair of tweezers.
  13. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 13, 1 resimden 1.
    • Use the flat end of a spudger to pry up the end of the large orange flex cable.
    • Remove the large orange flex cable.
  14. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 14, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 14, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 14, 3 resimden 3.
    • Use the flat end of a spudger to pry up the USB-C assembly from the lower portion of the phone.
    • Remove the USB-C assembly using a pair of tweezers.
  15. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 15, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 15, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 15, 3 resimden 3.
    • Disconnect the orange flex cable using a pair of tweezers.
    • Use a pair of tweezers to gently remove the vibrator assembly.
  16. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 16, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers to remove the earpiece assembly.
  17. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 17, 2 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 17, 2 resimden 2.
    • Use a pair of tweezers to remove the small black plastic piece located near the phone's upper lefthand corner.
  18. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 18, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 18, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 18, 3 resimden 3.
    • Use a pair of tweezers to disconnect the small orange flex cable.
    • Gently remove the assembly with the small orange flex cable using a pair of tweezers.
  19. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 19, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 19, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 19, 3 resimden 3.
    • Use a pair of tweezers to grasp the black plastic strip in the bottom left-hand corner of the battery.
    • Pull firmly on the black tab and wrap the adhesive strip around the tweezers.
    • Continue pulling outwards until the entire adhesive strip is removed.
  20. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 20, 3 resimden 1. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 20, 3 resimden 2. Xiaomi Redmi Note 8 Pro Screen Replacement: adım 20, 3 resimden 3.
    • Use the flat end of a spudger to pry up the battery.
    • Remove the battery.
    • Now, you can replace the phone's damaged screen-on-frame with a new screen-on-frame assembly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Selena
2.866 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 91
Her zaman: 4,708
