Giriş
This guide will show you how to replace the battery in your phone if it is old, damaged, or losing its charge too quickly. The replacement process is simple and only requires three steps.
Neye ihtiyacın var
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Geht das so einfach auch bei Redmi note 7 ???
Ich fürchte nein, sie ist als “nicht entfernbar" beschrieben.
VauWeh -
Wie sieht es beim Redmi Note 11 S aus?
