Ana içeriğe geç
Xiaomi Redmi Note Battery Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi Note Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Battery Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note Battery Replacement: adım 2, 2 resimden 2.
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Battery Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note Battery Replacement: adım 3, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Slater Stewart
270 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G4
4 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
Geht das so einfach auch bei Redmi note 7 ???
Ingeborg Langer - Yanıt
Ich fürchte nein, sie ist als “nicht entfernbar" beschrieben.
VauWeh -
Wie sieht es beim Redmi Note 11 S aus?
Schlotti P. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 98
Her zaman: 13,816
