Ana içeriğe geç
Xiaomi Redmi Note Charging Port Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi Note Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Charging Port Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note Charging Port Replacement: adım 2, 2 resimden 2.
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Charging Port Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note Charging Port Replacement: adım 3, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Charging Port Replacement, Midframe: adım 4, 2 resimden 1. Xiaomi Redmi Note Charging Port Replacement, Midframe: adım 4, 2 resimden 2.
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Charging Port Replacement: adım 5, 2 resimden 1. Xiaomi Redmi Note Charging Port Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Charging Port Replacement, Charging Port: adım 6, 2 resimden 1. Xiaomi Redmi Note Charging Port Replacement, Charging Port: adım 6, 2 resimden 2.
    • Locate the charging port panel at the bottom of the device.
    • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
  7. Xiaomi Redmi Note Charging Port Replacement: adım 7, 3 resimden 1. Xiaomi Redmi Note Charging Port Replacement: adım 7, 3 resimden 2. Xiaomi Redmi Note Charging Port Replacement: adım 7, 3 resimden 3.
    • Locate the antenna cable at the top right corner of the charging port.
    • Lift the antenna cable off of the panel with tweezers.
  8. Xiaomi Redmi Note Charging Port Replacement: adım 8, 3 resimden 1. Xiaomi Redmi Note Charging Port Replacement: adım 8, 3 resimden 2. Xiaomi Redmi Note Charging Port Replacement: adım 8, 3 resimden 3.
    • Flip the panel to its back side, but do not fully lift it off of the phone yet.
    • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
  9. Xiaomi Redmi Note Charging Port Replacement: adım 9, 1 resimden 1.
    • Lift the charging port up to remove it from the frame.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Caitlin Settles
738 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G4
4 Üyeler
16 adet Kılavuz yazıldı
9 Yorum
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - Yanıt
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - Yanıt
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - Yanıt
How much is it to repair in Qatar riyal
Cynthia - Yanıt
How much does it cost to repair the charging port in Qatar royals?
Cynthia - Yanıt
from Usd4 to Usd 10, I paid 8 dollars for
Yvan R -
Caitlin can you advise where replacement part could be procured online?
svedanny - Yanıt
hi, I replaced the charge port, phone charges but the screen touch does not respond, any ideas how to fix this problem?
Yvan R - Yanıt
After changing the same as mentioned above steps, my phone display went off.. is there any thing I missed or is there any pins releaded to display. Plz help.
Rafi Shaik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 111
Her zaman: 37,620
