Ana içeriğe geç
Xiaomi Redmi Note Motherboard Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi Note Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Motherboard Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 2, 2 resimden 2.
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Motherboard Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 3, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Motherboard Replacement, Midframe: adım 4, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement, Midframe: adım 4, 2 resimden 2.
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Motherboard Replacement: adım 5, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: adım 6, 3 resimden 1. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: adım 6, 3 resimden 2. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Xiaomi Redmi Note Motherboard Replacement, Rear Camera: adım 7, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement, Rear Camera: adım 7, 2 resimden 2.
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Xiaomi Redmi Note Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Locate the three ZIF connectors on the motherboard.
  9. Xiaomi Redmi Note Motherboard Replacement: adım 9, 3 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 9, 3 resimden 2. Xiaomi Redmi Note Motherboard Replacement: adım 9, 3 resimden 3.
    Satın Al
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Xiaomi Redmi Note Motherboard Replacement: adım 10, 3 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 10, 3 resimden 2. Xiaomi Redmi Note Motherboard Replacement: adım 10, 3 resimden 3.
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Xiaomi Redmi Note Motherboard Replacement: adım 11, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the two 2.9mm Philips #00 screws.
  12. Xiaomi Redmi Note Motherboard Replacement: adım 12, 3 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 12, 3 resimden 2. Xiaomi Redmi Note Motherboard Replacement: adım 12, 3 resimden 3.
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Xiaomi Redmi Note Motherboard Replacement: adım 13, 2 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 13, 2 resimden 2.
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Xiaomi Redmi Note Motherboard Replacement: adım 14, 3 resimden 1. Xiaomi Redmi Note Motherboard Replacement: adım 14, 3 resimden 2. Xiaomi Redmi Note Motherboard Replacement: adım 14, 3 resimden 3.
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
AJ Beers
213 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G4
4 Üyeler
16 adet Kılavuz yazıldı
5 Yorum
Good explanation, but the question is : Where to get Xiaomi replacement motherboards ?
Adriano Fonseca - Yanıt
can we shift bords memory to other bord
krishna - Yanıt
No we can't get motherboard's memory if it is damaged
sai teja -
Besten Dank an alle für Die Mühe, die sie sich jeweils geben um verständliche Anleitungen zu erstellen,
Oigres Ailgevar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 100
Her zaman: 24,915
