Ana içeriğe geç
Xiaomi Redmi Note Rear Camera Replacement
Neye ihtiyacın var
    1. Xiaomi Redmi Note Rear Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Redmi Note Rear Camera Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note Rear Camera Replacement: adım 2, 2 resimden 2.
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Redmi Note Rear Camera Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note Rear Camera Replacement: adım 3, 2 resimden 2.
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Redmi Note Rear Camera Replacement, Midframe: adım 4, 2 resimden 1. Xiaomi Redmi Note Rear Camera Replacement, Midframe: adım 4, 2 resimden 2.
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Redmi Note Rear Camera Replacement: adım 5, 2 resimden 1. Xiaomi Redmi Note Rear Camera Replacement: adım 5, 2 resimden 2.
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: adım 6, 2 resimden 1. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: adım 6, 2 resimden 2.
      • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
AJ Beers
213 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G4
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 4,286
