Ana içeriğe geç
Xiaomi Yi Front Panel Replacement
Neye ihtiyacın var
    1. Xiaomi Yi Front Panel Replacement, Battery: adım 1, 2 resimden 1. Xiaomi Yi Front Panel Replacement, Battery: adım 1, 2 resimden 2.
      • Push the battery door switch to the left.
      • Lift the battery door up.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Yi Front Panel Replacement: adım 2, 3 resimden 1. Xiaomi Yi Front Panel Replacement: adım 2, 3 resimden 2. Xiaomi Yi Front Panel Replacement: adım 2, 3 resimden 3.
      • Lift the battery tab up.
      • Remove the battery by pulling the removal tab.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Yi Front Panel Replacement, Front Panel: adım 3, 2 resimden 1. Xiaomi Yi Front Panel Replacement, Front Panel: adım 3, 2 resimden 2.
      • Introduce the plastic opening tool into any of the sides of the camera.
      • Pry with the plastic opening tool at the seam between the front and the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Yi Front Panel Replacement: adım 4, 3 resimden 1. Xiaomi Yi Front Panel Replacement: adım 4, 3 resimden 2. Xiaomi Yi Front Panel Replacement: adım 4, 3 resimden 3.
      • Slide prying tool along the seam until front panel is fully separated from the back panel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
William Zipperer
711 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G5
3 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Yanıt Paylaş
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam - Yanıt Paylaş
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 3,342
