Ana içeriğe geç
Xiaomi Yi Microphone Replacement
Neye ihtiyacın var
  1. Xiaomi Yi Microphone Replacement, Battery: adım 1, 2 resimden 1. Xiaomi Yi Microphone Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Microphone Replacement: adım 2, 3 resimden 1. Xiaomi Yi Microphone Replacement: adım 2, 3 resimden 2. Xiaomi Yi Microphone Replacement: adım 2, 3 resimden 3.
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Microphone Replacement, Front Panel: adım 3, 2 resimden 1. Xiaomi Yi Microphone Replacement, Front Panel: adım 3, 2 resimden 2.
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Microphone Replacement: adım 4, 3 resimden 1. Xiaomi Yi Microphone Replacement: adım 4, 3 resimden 2. Xiaomi Yi Microphone Replacement: adım 4, 3 resimden 3.
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Microphone Replacement, Back Panel: adım 5, 2 resimden 1. Xiaomi Yi Microphone Replacement, Back Panel: adım 5, 2 resimden 2.
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Microphone Replacement: adım 6, 3 resimden 1. Xiaomi Yi Microphone Replacement: adım 6, 3 resimden 2. Xiaomi Yi Microphone Replacement: adım 6, 3 resimden 3.
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Microphone Replacement: adım 7, 2 resimden 1. Xiaomi Yi Microphone Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Microphone Replacement, Microphone: adım 8, 2 resimden 1. Xiaomi Yi Microphone Replacement, Microphone: adım 8, 2 resimden 2.
    • Locate the solder points connected to the red and black wire on the back of the motherboard.
  9. Xiaomi Yi Microphone Replacement: adım 9, 1 resimden 1.
    • Heat these two points with a Soldering Iron and remove the microphone. Reapply fresh solder with the replacement microphone.
    • Soldering Irons are very hot and fumes from melted solder can cause irritation. Use only in a clean, well ventilated area.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Matt Bibby
528 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G5
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
My camera came with the microphone not soldered at all (two microphone wires were hanging above the motherboard with no sign of soldering).
That was an easy repair as soon as I figured out what's the culprit, but before I've blamed the software for this issue for two days and tinkered with the software for at least 6 hours with no result.
adryjanowski, very nice tutorial, thank you!
Ivan Elizarov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 7,750
