Ana içeriğe geç
Xiaomi Yi Motherboard Replacement
Neye ihtiyacın var
  1. Xiaomi Yi Motherboard Replacement, Battery: adım 1, 2 resimden 1. Xiaomi Yi Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Motherboard Replacement: adım 2, 3 resimden 1. Xiaomi Yi Motherboard Replacement: adım 2, 3 resimden 2. Xiaomi Yi Motherboard Replacement: adım 2, 3 resimden 3.
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Motherboard Replacement, Front Panel: adım 3, 2 resimden 1. Xiaomi Yi Motherboard Replacement, Front Panel: adım 3, 2 resimden 2.
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Motherboard Replacement: adım 4, 3 resimden 1. Xiaomi Yi Motherboard Replacement: adım 4, 3 resimden 2. Xiaomi Yi Motherboard Replacement: adım 4, 3 resimden 3.
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Motherboard Replacement, Back Panel: adım 5, 2 resimden 1. Xiaomi Yi Motherboard Replacement, Back Panel: adım 5, 2 resimden 2.
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Motherboard Replacement: adım 6, 3 resimden 1. Xiaomi Yi Motherboard Replacement: adım 6, 3 resimden 2. Xiaomi Yi Motherboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Motherboard Replacement: adım 7, 2 resimden 1. Xiaomi Yi Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Xiaomi Yi Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
    • Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
  9. Xiaomi Yi Motherboard Replacement: adım 9, 3 resimden 1. Xiaomi Yi Motherboard Replacement: adım 9, 3 resimden 2. Xiaomi Yi Motherboard Replacement: adım 9, 3 resimden 3.
    Satın Al
    • Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard.
    • Using the tweezers gently remove the spacer block and set aside.
  10. Xiaomi Yi Motherboard Replacement: adım 10, 2 resimden 1. Xiaomi Yi Motherboard Replacement: adım 10, 2 resimden 2.
    • Pry gently using the flat end of the black spudger to remove the ribbon connector.
    • Lift the lens assembly up and away from the motherboard.
    • Motherboard remains.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
William Zipperer
711 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G5
3 Üyeler
10 adet Kılavuz yazıldı
8 Yorum
Where you buy motherboard for xiaomi yi ?
diamond1981 - Yanıt
I wonder where I can buy this part ribbon connector to buy.
viilelaa - Yanıt
Link for buying it waaaaaaaay cheaper:http://bit.ly/XiaoMiYi1080P
tozilen - Yanıt
Great guide but useless, there is no spare parts on the market for this camera
Nebojsa Rosic - Yanıt
IC repair is always possible
AdamA -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 12,559
