Giriş
This guide will show you how to open the XtremeMac Luna so that its inner components are easily accessible.
Parçalar
Hiçbir parçaya gerek yok.
  1. Flip the device over so that the batteries are closest to you. Remove the battery lid by pressing the battery cover's tab and pulling it away from the device. Push the battery against the spring and lift it out of the casing.
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  4. Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you. Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
Sonuç
Daniel Johnson
1 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G47
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 264
