Giriş
If your Luna is no longer picking up radio signals, it may be due to a faulty radio jack. Replace it in a few simple steps.
Parçalar
Hiçbir parçaya gerek yok.
Flip the device over so that the batteries are closest to you.
Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
Push the battery against the spring and lift it out of the casing.
Repeat with the other battery.
Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
Remove the two 12mm Phillips head screws from the back of the device using a Phillips #1 screwdriver.
