Ana içeriğe geç
Yamaha FG-425 Guitar String Replacement
Neye ihtiyacın var
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: adım 1, 3 resimden 1. Yamaha FG-425 Guitar String Replacement, Guitar String: adım 1, 3 resimden 2. Yamaha FG-425 Guitar String Replacement, Guitar String: adım 1, 3 resimden 3.
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: adım 2, 2 resimden 1. Yamaha FG-425 Guitar String Replacement: adım 2, 2 resimden 2.
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: adım 3, 2 resimden 1. Yamaha FG-425 Guitar String Replacement: adım 3, 2 resimden 2.
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: adım 4, 3 resimden 1. Yamaha FG-425 Guitar String Replacement: adım 4, 3 resimden 2. Yamaha FG-425 Guitar String Replacement: adım 4, 3 resimden 3.
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: adım 5, 2 resimden 1. Yamaha FG-425 Guitar String Replacement: adım 5, 2 resimden 2.
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: adım 6, 1 resimden 1.
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: adım 7, 1 resimden 1.
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Nicole Francheska Letigio
207 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 218
