Ana içeriğe geç
Yamaha NS-AW190BL Rear Casing Replacement
Neye ihtiyacın var
  1. Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: adım 1, 2 resimden 1. Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: adım 1, 2 resimden 2.
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Rear Casing Replacement: adım 2, 3 resimden 1. Yamaha NS-AW190BL Rear Casing Replacement: adım 2, 3 resimden 2. Yamaha NS-AW190BL Rear Casing Replacement: adım 2, 3 resimden 3.
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Rear Casing Replacement: adım 3, 3 resimden 1. Yamaha NS-AW190BL Rear Casing Replacement: adım 3, 3 resimden 2. Yamaha NS-AW190BL Rear Casing Replacement: adım 3, 3 resimden 3.
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Rear Casing Replacement: adım 4, 2 resimden 1. Yamaha NS-AW190BL Rear Casing Replacement: adım 4, 2 resimden 2.
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
Sonuç
Nick Ruiz
331 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 821
