Ana içeriğe geç
Yamaha YZF-R6 Fan Relay Replacement
Neye ihtiyacın var
  1. Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: adım 1, 3 resimden 1. Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: adım 1, 3 resimden 2. Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: adım 1, 3 resimden 3.
    • Use your motorcycle's key to open the rear seat, and remove the seat to access the tool pouch.
  2. Yamaha YZF-R6 Fan Relay Replacement: adım 2, 2 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 2, 2 resimden 2.
    • Use a 10 mm Allen key to remove the front seat and expose the battery.
  3. Yamaha YZF-R6 Fan Relay Replacement: adım 3, 2 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 3, 2 resimden 2.
    • Using a Phillips-head screwdriver, remove the screws attached to the battery terminals.
  4. Yamaha YZF-R6 Fan Relay Replacement: adım 4, 3 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 4, 3 resimden 2. Yamaha YZF-R6 Fan Relay Replacement: adım 4, 3 resimden 3.
    • Using the 10mm Allen key, remove the hardware securing the left side fairings.
  5. Yamaha YZF-R6 Fan Relay Replacement: adım 5, 3 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 5, 3 resimden 2. Yamaha YZF-R6 Fan Relay Replacement: adım 5, 3 resimden 3.
    • Remove the middle fairing on the left-hand side, and carefully unclip the turn signal cable.
  6. Yamaha YZF-R6 Fan Relay Replacement: adım 6, 3 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 6, 3 resimden 2. Yamaha YZF-R6 Fan Relay Replacement: adım 6, 3 resimden 3.
    • Once you have removed the left-hand cover under the clutch lever, locate the relay assemblies for the lights and cooling fans.
  7. Yamaha YZF-R6 Fan Relay Replacement: adım 7, 2 resimden 1. Yamaha YZF-R6 Fan Relay Replacement: adım 7, 2 resimden 2.
    • Use a flat-head screwdriver to gently pry the locking mechanism open on the relay assembly. You can remove the relay by itself or with the bracket assembly.
Sonuç
Jose Perez 323
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 45
Her zaman: 275
