Ana içeriğe geç
Yocan UNI Pro Disassembly
  1. Yocan UNI Pro Disassembly, Outer Screws: adım 1, 3 resimden 1. Yocan UNI Pro Disassembly, Outer Screws: adım 1, 3 resimden 2. Yocan UNI Pro Disassembly, Outer Screws: adım 1, 3 resimden 3.
    • Remove 2 Phillips head screws. There is one on each side of the device
  2. Yocan UNI Pro Disassembly, Housing Removal: adım 2, 3 resimden 1. Yocan UNI Pro Disassembly, Housing Removal: adım 2, 3 resimden 2. Yocan UNI Pro Disassembly, Housing Removal: adım 2, 3 resimden 3.
    • Flip the device over and pull the cover upwards
  3. Yocan UNI Pro Disassembly, Aperture Removal: adım 3, 3 resimden 1. Yocan UNI Pro Disassembly, Aperture Removal: adım 3, 3 resimden 2. Yocan UNI Pro Disassembly, Aperture Removal: adım 3, 3 resimden 3.
    • Remove the aperture adjustment holder
  4. Yocan UNI Pro Disassembly, O-Ring: adım 4, 2 resimden 1. Yocan UNI Pro Disassembly, O-Ring: adım 4, 2 resimden 2.
    • Remove O-Ring
  5. Yocan UNI Pro Disassembly, Buttons and Shutter Pieces: adım 5, 2 resimden 1. Yocan UNI Pro Disassembly, Buttons and Shutter Pieces: adım 5, 2 resimden 2.
    • Remove buttons and aperture/shutter pieces
    • They should just fall out. If not, they can be removed with your fingers
  6. Yocan UNI Pro Disassembly, Inner Plasic: adım 6, 2 resimden 1. Yocan UNI Pro Disassembly, Inner Plasic: adım 6, 2 resimden 2.
    • Grip the bottom and top of the device and pull up slightly
    • The next step will fully remove it
  7. Yocan UNI Pro Disassembly, Full Electronics Removal: adım 7, 3 resimden 1. Yocan UNI Pro Disassembly, Full Electronics Removal: adım 7, 3 resimden 2. Yocan UNI Pro Disassembly, Full Electronics Removal: adım 7, 3 resimden 3.
    • Pull the clear plastic out and away to the left
    • Pull up at an angle
  8. Yocan UNI Pro Disassembly, Kapton Tape Removal: adım 8, 3 resimden 1. Yocan UNI Pro Disassembly, Kapton Tape Removal: adım 8, 3 resimden 2. Yocan UNI Pro Disassembly, Kapton Tape Removal: adım 8, 3 resimden 3.
    • Peel the Kapton Tape off of the battery and clear plastic
  9. Yocan UNI Pro Disassembly, PCB Slide Out: adım 9, 2 resimden 1. Yocan UNI Pro Disassembly, PCB Slide Out: adım 9, 2 resimden 2.
    • Slide the circuit board back so that it is not under the plastic lip
  10. Yocan UNI Pro Disassembly, Battery Adhesive Removal: adım 10, 3 resimden 1. Yocan UNI Pro Disassembly, Battery Adhesive Removal: adım 10, 3 resimden 2. Yocan UNI Pro Disassembly, Battery Adhesive Removal: adım 10, 3 resimden 3.
    • Slowly peel the battery and circuit board away from the plastic housing
    • There is some adhesive under the battery so be careful
  11. Yocan UNI Pro Disassembly, Height Adjustment Module: adım 11, 3 resimden 1. Yocan UNI Pro Disassembly, Height Adjustment Module: adım 11, 3 resimden 2. Yocan UNI Pro Disassembly, Height Adjustment Module: adım 11, 3 resimden 3.
    • Grip the plastic case and use your thumb to remove the height adjustment module
    • It should slide out all the way
    • The ball bearings in the next step might fall out right away so be careful that they don't roll away!
  12. Yocan UNI Pro Disassembly, Ball Bearings: adım 12, 3 resimden 1. Yocan UNI Pro Disassembly, Ball Bearings: adım 12, 3 resimden 2. Yocan UNI Pro Disassembly, Ball Bearings: adım 12, 3 resimden 3.
    • There are two ball bearings that make the height adjustment module work and lock into position.
    • There is one on each side and they easily fall out so be careful
  13. Yocan UNI Pro Disassembly, Motherboard and Battery Closeup: adım 13, 2 resimden 1. Yocan UNI Pro Disassembly, Motherboard and Battery Closeup: adım 13, 2 resimden 2.
    • Just some pretty pictures
  14. Yocan UNI Pro Disassembly, Screen Removal: adım 14, 3 resimden 1. Yocan UNI Pro Disassembly, Screen Removal: adım 14, 3 resimden 2. Yocan UNI Pro Disassembly, Screen Removal: adım 14, 3 resimden 3.
    • Use a spudger to carefully remove the screen
    • It is held down with adhesive
    • There is no way to remove the screen completely unless you get rid of the red strain relief material and desolder it from the board
  15. Yocan UNI Pro Disassembly, Shutter Reassembly: adım 15, 3 resimden 1. Yocan UNI Pro Disassembly, Shutter Reassembly: adım 15, 3 resimden 2. Yocan UNI Pro Disassembly, Shutter Reassembly: adım 15, 3 resimden 3.
    • For reassembly, place the slots on the small shutter pieces into the circular holder
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
ShellingRook27
2.244 İtibar
7 adet Kılavuz yazıldı
Ekip
Repair For You Repair For You üyesi
Business
1 Üye
12 adet Kılavuz yazıldı
10Kılavuz Yorumları
I got a cartridge stuck in mine... avoid the 2 gram DOZOs, they're so poorly made that just putting it in you can't get it out normally!
Joe Drew - Yanıt
I somehow managed to get a single hair under the casing and over the screen on my Yocan Uni Pro. With the help of this guide, I was able to disassemble, clean, and re-assemble my vape quickly and easily - I'm especially grateful for the pictures showing how to disassemble/reassemble the shutter pieces. Thank you so much for this awesome guide!
Amy Kaufman - Yanıt
Thank you! Needed to clean my device and man oh man was I struggling with the shutter reassembly! Thanks so much for the time and effort for this guide, seriously helpful!
BingBong - Yanıt
While reassembling my 2.0 I accidentally touched the front metal shield to the “C1” on the circuit board and shorted it. Whole battery is cooked. Oops. Don’t make my mistake.
Will - Yanıt
This post literally saved me from buying a new battery. The slider was virtually glued to the case and seized up, and I had to push the cart at an angle just to get it to work and I could not figure out how to get it clean. Now it’s clean fully functional again!
Having access to a computer repair toolkit helped make quick work with these instructions but honestly anyone could probably follow these with a small eye glass screwdriver (and some rubbing alcohol and towels) to do the job, with maybe some sturdy tooth picks for the crevices
Kenneth Robinson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 116
Son 30 gün: 463
Her zaman: 12,116
