Ana içeriğe geç
Yoton YB02 Microphone Replacement
Neye ihtiyacın var
  1. Yoton YB02 Microphone Replacement, Microphone: adım 1, 2 resimden 1. Yoton YB02 Microphone Replacement, Microphone: adım 1, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Yoton YB02 Microphone Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry off the back panel from the camera.
    • It is recommended to pry at the edges of the panel and run through the edge of the panel.
    FixBot'a Sor
    Yorum Ekle
  3. Yoton YB02 Microphone Replacement: adım 3, 2 resimden 1. Yoton YB02 Microphone Replacement: adım 3, 2 resimden 2.
    • With the soldering iron, desolder the pin holding the microphone in place on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Yoton YB02 Microphone Replacement: adım 4, 3 resimden 1. Yoton YB02 Microphone Replacement: adım 4, 3 resimden 2. Yoton YB02 Microphone Replacement: adım 4, 3 resimden 3.
    • Carefully slide the microphone and microphone cable through the back panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
hsisson
811 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 293
