Ana içeriğe geç
Yujin Robot iCLEBO Arte Filter Replacement
  1. Yujin Robot iCLEBO Arte Filter Replacement, Dust Bin: adım 1, 1 resimden 1.
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Filter Replacement: adım 2, 2 resimden 1. Yujin Robot iCLEBO Arte Filter Replacement: adım 2, 2 resimden 2.
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Filter Replacement, Filter: adım 3, 1 resimden 1.
    • Push the yellow tab releasing the filter harness.
  4. Yujin Robot iCLEBO Arte Filter Replacement: adım 4, 1 resimden 1.
    • Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
Sonuç
To finish reassembling your device, follow these instructions in reverse order.
Nathan Clark
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 322
