Ana içeriğe geç
Yujin Robot iCLEBO Arte Main Brush Replacement
Neye ihtiyacın var
  1. Yujin Robot iCLEBO Arte Main Brush Replacement, Dust Bin: adım 1, 1 resimden 1.
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 2, 2 resimden 1. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 2, 2 resimden 2.
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: adım 3, 3 resimden 1. Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: adım 3, 3 resimden 2. Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: adım 3, 3 resimden 3.
    • Flip over the device to access the brush cover.
    • To remove the brush cover, push together the two snap releases on the right and left sides of the cover until it releases.
    • Do not push the release snaps too close together. Doing so may cause them to break and the brush could fall out when in use.
  4. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 4, 2 resimden 1. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 4, 2 resimden 2.
    • Grip the left side of the brush with the square end-piece and pull up until the brush pops out.
  5. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 5, 3 resimden 1. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 5, 3 resimden 2. Yujin Robot iCLEBO Arte Main Brush Replacement: adım 5, 3 resimden 3.
    • When preparing a new brush, it is very important to make sure that the new one is equipped with the proper end-pieces.
    • Take the round metal piece and slide it into the square rubber coating. Then, stick it on the end with the metal peg.
Sonuç
Trent Treiber
204 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 908
