Ana içeriğe geç
Yujin Robot iCLEBO Arte Power Transformer Replacement
    1. Yujin Robot iCLEBO Arte Power Transformer Replacement, Power Transformer: adım 1, 1 resimden 1.
      • Unplug transformer before performing operations on it!
      • Press on the two black plastic tabs to remove the rear cover for the charging base.
      FixBot'a Sor
      Yorum Ekle
    2. Yujin Robot iCLEBO Arte Power Transformer Replacement: adım 2, 1 resimden 1.
      • Remove the long cable from inside the base and gently pull the connector from the base.
      FixBot'a Sor
      Yorum Ekle
    3. Yujin Robot iCLEBO Arte Power Transformer Replacement: adım 3, 1 resimden 1.
      • Pull out and remove the old cable from inside the charging base.
      • Detach the thicker part of the cord from the black transformer box.
      FixBot'a Sor
      Yorum Ekle
    4. Yujin Robot iCLEBO Arte Power Transformer Replacement: adım 4, 1 resimden 1.
      • Replace the new thick cable with the old cable just removed. Make sure the cable can fit into the wall before discarding the other cable. If you are residing in the US, this is the connector you need to use.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Trent Bingel
437 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G3
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 848
