Ana içeriğe geç
Yuneec Breeze 4K Camera Replacement
Neye ihtiyacın var
    1. Yuneec Breeze 4K Camera Replacement, Camera: adım 1, 2 resimden 1. Yuneec Breeze 4K Camera Replacement, Camera: adım 1, 2 resimden 2.
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Yuneec Breeze 4K Camera Replacement: adım 2, 1 resimden 1.
      • Using small pliers grip the connector of the wire and pull it out slowly.
      FixBot'a Sor
      Yorum Ekle
    3. Yuneec Breeze 4K Camera Replacement: adım 3, 1 resimden 1.
      • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
      FixBot'a Sor
      Yorum Ekle
    4. Yuneec Breeze 4K Camera Replacement: adım 4, 1 resimden 1.
      • Unplug the two vertical plugs located in the rear of the M7 board.
      FixBot'a Sor
      Yorum Ekle
    5. Yuneec Breeze 4K Camera Replacement: adım 5, 1 resimden 1.
      • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
      FixBot'a Sor
      Yorum Ekle
    6. Yuneec Breeze 4K Camera Replacement: adım 6, 1 resimden 1.
      • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
      FixBot'a Sor
      Yorum Ekle
    7. Yuneec Breeze 4K Camera Replacement: adım 7, 2 resimden 1. Yuneec Breeze 4K Camera Replacement: adım 7, 2 resimden 2.
      • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
      FixBot'a Sor
      Yorum Ekle
    8. Yuneec Breeze 4K Camera Replacement: adım 8, 1 resimden 1.
      • Using a pair of pliers pull apart the battery connector.
      FixBot'a Sor
      Yorum Ekle
    9. Yuneec Breeze 4K Camera Replacement: adım 9, 1 resimden 1.
      • Flip over the entire frame along with the M7 board and the A9 board.
      FixBot'a Sor
      Yorum Ekle
    10. Yuneec Breeze 4K Camera Replacement: adım 10, 1 resimden 1.
      • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
      FixBot'a Sor
      Yorum Ekle
    11. Yuneec Breeze 4K Camera Replacement: adım 11, 1 resimden 1.
      • Unplug the only wire that is connected to the A9 board.
      FixBot'a Sor
      Yorum Ekle
    12. Yuneec Breeze 4K Camera Replacement: adım 12, 1 resimden 1.
      • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
      FixBot'a Sor
      Yorum Ekle
    13. Yuneec Breeze 4K Camera Replacement: adım 13, 1 resimden 1.
      • Unscrew the four screws that are holding the camera to the frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Wes Knutson
481 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G5
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 2,428
