Ana içeriğe geç
Yuneec Breeze 4K Motherboard Replacement
Neye ihtiyacın var
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: adım 1, 2 resimden 1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: adım 1, 2 resimden 2.
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: adım 2, 3 resimden 1. Yuneec Breeze 4K Motherboard Replacement: adım 2, 3 resimden 2. Yuneec Breeze 4K Motherboard Replacement: adım 2, 3 resimden 3.
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: adım 5, 2 resimden 1. Yuneec Breeze 4K Motherboard Replacement: adım 5, 2 resimden 2.
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: adım 6, 3 resimden 1. Yuneec Breeze 4K Motherboard Replacement: adım 6, 3 resimden 2. Yuneec Breeze 4K Motherboard Replacement: adım 6, 3 resimden 3.
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: adım 7, 3 resimden 1. Yuneec Breeze 4K Motherboard Replacement: adım 7, 3 resimden 2. Yuneec Breeze 4K Motherboard Replacement: adım 7, 3 resimden 3.
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: adım 8, 1 resimden 1.
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: adım 9, 2 resimden 1. Yuneec Breeze 4K Motherboard Replacement: adım 9, 2 resimden 2.
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ryanne Millis
318 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G5
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Excellent step by step instructions.
paul_courville - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,932
