Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
To disconnect the battery from the remote, grab the red and black connectors.
Pull gently on connectors until they disconnect.
Grab ahold of the top of the black cap on the button with the pliers and pull up forcefully.
Twist counter clockwise on the silver portion of the device with a pair of pliers.
Slide the Jimmy underneath the rubber grips and pry upwards.
With your free hand grasp the rubber grips and pull upward to remove it.
Remove the six 1.3 cm screws located on the back panel of the remote using the 5.5mm hex screw bit.
Remove the four 6mm screws from the handle using the 4mm hex driver bit.
Carefully pull up and over on the back panel to remove. Take your time because there are wires connecting the two panels that can easily torn.
Flip your device.
Once the silver cover holding the switch in place is removed, remove the switch by grabbing it and pulling back towards you.
Once the switch is removed, disconnect the switch from the circuit board by pulling the cable from the cable connector.
