Giriş
Replacing the screen of your device can be a daunting task, but this guide will help you easily and safely replace it. Choosing to do this can be caused by cracking the screen due to dropping the controller, or water damage.
Neye ihtiyacın var
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
Slide the Jimmy underneath the rubber grips and pry upwards.
With your free hand grasp the rubber grips and pull upward to remove it.
Bir başkası bu kılavuzu tamamladı.
