Ana içeriğe geç
Yuneec ST16S Carrying Handle Replacement
Neye ihtiyacın var
    1. Yuneec ST16S Carrying Handle Replacement, Battery: adım 1, 1 resimden 1.
      • Hold down the button located above the battery while applying downward pressure to the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Yuneec ST16S Carrying Handle Replacement: adım 2, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 2, 2 resimden 2.
      • While still holding down the button, slide the battery out of its slot.
      FixBot'a Sor
      Yorum Ekle
    1. Yuneec ST16S Carrying Handle Replacement, Backplate: adım 3, 1 resimden 1.
      • Remove the single screw from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Yuneec ST16S Carrying Handle Replacement: adım 4, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 4, 2 resimden 2.
      • Remove the rubber bumpers from the back of the device using a spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Yuneec ST16S Carrying Handle Replacement: adım 5, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 5, 2 resimden 2.
      • Remove the two screws located under each of the rubber bumpers.
      FixBot'a Sor
      Yorum Ekle
    4. Yuneec ST16S Carrying Handle Replacement: adım 6, 3 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 6, 3 resimden 2. Yuneec ST16S Carrying Handle Replacement: adım 6, 3 resimden 3.
      • Remove the three screws along the top of the device.
      FixBot'a Sor
      Yorum Ekle
    5. Yuneec ST16S Carrying Handle Replacement: adım 7, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 7, 2 resimden 2.
      • Carefully remove the backplate from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Yuneec ST16S Carrying Handle Replacement, Carrying Handle: adım 8, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement, Carrying Handle: adım 8, 2 resimden 2.
      • Remove the screws from the clips on both ends of the handle.
      FixBot'a Sor
      Yorum Ekle
    2. Yuneec ST16S Carrying Handle Replacement: adım 9, 2 resimden 1. Yuneec ST16S Carrying Handle Replacement: adım 9, 2 resimden 2.
      • Slide the clips away from the handle.
      FixBot'a Sor
      Yorum Ekle
    3. Yuneec ST16S Carrying Handle Replacement: adım 10, 1 resimden 1.
      • Remove the handle from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Christian Resendes
589 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 202
