Ana içeriğe geç
Yuneec ST16S Joystick Replacement
Neye ihtiyacın var
  1. Yuneec ST16S Joystick Replacement, Battery: adım 1, 1 resimden 1.
    • Hold down the button located above the battery while applying downward pressure to the battery.
  2. Yuneec ST16S Joystick Replacement: adım 2, 2 resimden 1. Yuneec ST16S Joystick Replacement: adım 2, 2 resimden 2.
    • While still holding down the button, slide the battery out of its slot.
  3. Yuneec ST16S Joystick Replacement, Backplate: adım 3, 1 resimden 1.
    • Remove the single screw from the battery compartment.
  4. Yuneec ST16S Joystick Replacement: adım 4, 2 resimden 1. Yuneec ST16S Joystick Replacement: adım 4, 2 resimden 2.
    • Remove the rubber bumpers from the back of the device using a spudger.
  5. Yuneec ST16S Joystick Replacement: adım 5, 2 resimden 1. Yuneec ST16S Joystick Replacement: adım 5, 2 resimden 2.
    • Remove the two screws located under each of the rubber bumpers.
  6. Yuneec ST16S Joystick Replacement: adım 6, 3 resimden 1. Yuneec ST16S Joystick Replacement: adım 6, 3 resimden 2. Yuneec ST16S Joystick Replacement: adım 6, 3 resimden 3.
    • Remove the three screws along the top of the device.
  7. Yuneec ST16S Joystick Replacement: adım 7, 2 resimden 1. Yuneec ST16S Joystick Replacement: adım 7, 2 resimden 2.
    • Carefully remove the backplate from the device.
  8. Yuneec ST16S Joystick Replacement, Joystick: adım 8, 1 resimden 1.
    • Remove the four screws from around the joystick.
  9. Yuneec ST16S Joystick Replacement: adım 9, 1 resimden 1.
    • Unplug the joystick from the device.
  10. Yuneec ST16S Joystick Replacement: adım 10, 1 resimden 1.
    • Remove the joystick from the device.
Sonuç
Christian Resendes
589 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 86
