Ana içeriğe geç
Yuneec Typhoon H Gimbal Bushing Reattachment
Neye ihtiyacın var
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: adım 1, 2 resimden 1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: adım 1, 2 resimden 2.
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: adım 2, 3 resimden 1. Yuneec Typhoon H Gimbal Bushing Reattachment: adım 2, 3 resimden 2. Yuneec Typhoon H Gimbal Bushing Reattachment: adım 2, 3 resimden 3.
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Sonuç
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 farklı kişi bu kılavuzu tamamladı.
Jake Breul
127 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G3
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Camera not getting power after crash.
Don - Yanıt
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Yanıt
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,618
