Ana içeriğe geç
Yuneec Typhoon H LED Board Replacement
Neye ihtiyacın var
  1. Yuneec Typhoon H LED Board Replacement, LED Board: adım 1, 1 resimden 1.
    • This guide begins with the propeller already removed.
  2. Yuneec Typhoon H LED Board Replacement: adım 2, 2 resimden 1. Yuneec Typhoon H LED Board Replacement: adım 2, 2 resimden 2.
    • Turn the drone upside down to have easy access to the prop arm.
    • Twist out the prop motor clockwise.
  3. Yuneec Typhoon H LED Board Replacement: adım 3, 1 resimden 1.
    • Unscrew two 4.9mm screws on the board using a Phillips #000 screwdriver.
  4. Yuneec Typhoon H LED Board Replacement: adım 4, 2 resimden 1. Yuneec Typhoon H LED Board Replacement: adım 4, 2 resimden 2.
    • Hold the LED board in one hand and pinch the plug at the connection to the board with the other hand.
    • Pull the plug out from the connection piece.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Claire Luce
371 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 479
